Secure your home with the best price yet on this voice-activated Ring Alarm system
Ring Alarm
Ring Alarm
You're probably already familiar with the Ring Video Doorbell, and you might have even grabbed one recently thanks to that sale on refurbished models for $60, but the Ring Alarm is the next best Ring product you need for your home. Luckily, this is also your chance to snag the system at a discount, as Amazon has the 14-piece security system bundled with the Echo Dot smart speaker on sale for $279 today. At $50 off, you'll be snagging its lowest price yet.
The Ring Alarm home security system utilizes the same app that the Ring Video Doorbell uses, allowing you to manage both easily from anywhere in the world. There are other, more affordable Ring Alarm configurations as well, though this 14-piece version is one of the most robust as it comes with two keypads, eight contact sensors to place on your doors or windows, two motion detectors, a range extender, and the required base station that helps everything work together. With the included Echo Dot speaker, you'll even be able to voice control the alarm, including arming, disarming, and checking its status.
Ring offers optional 24/7 professional monitoring of its alarm systems for $10 per month with no contract required and no cancellation fees. It's all extremely easy to set up and customize too.
