Say it while you stream with the best price on Razer's Seiren X Microphone
The Razer Seiren X Microphone usually costs $99.99, but right now, Amazon is offering it for only $67.95. That deal is valid on the Black color scheme and brings it down to the best price we've ever seen.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
This well-rated microphone has a super cardioid pickup pattern, which is focused more tightly than other mics you may have used. That means background noise will be reduced. The built-in shock mount dampens vibrations for even crisper audio. This mic is designed to make your voice sound natural and clear, and there's zero-latency monitoring so you can hear yourself in real time without that annoying and distracting echo effect. All of this is packed into a sleek little footprint, so you can keep the Seiren X on your desk or take it with you to events without a bunch of bulk.
If you're on the hunt for more streaming savings, be sure to shop on Prime Day. There's always tons of tech on sale. It's coming up in only a couple of weeks!
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
