This 50% discount on Razer's Lancehead Wireless Optical Gaming Mouse is worth a click
Thanks to Best Buy's Deals of the Day, the Razer Lancehead Wireless Optical Gaming Mouse is down to $59.99 for one day only. At 50% off its regular cost, you'll be scoring this wireless gaming mouse for one of the best prices we've ever seen it reach.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
This mouse was recently updated with a 16,000 DPI 5G optical sensor and a rechargeable battery that can last for up to 50 hours, giving gamers all the more reason to give it a look. It uses a wireless USB dongle to connect to your computer, either Windows or Mac, and has an ambidextrous design that makes it comfortable to use no matter if you're left- or right-handed.
Powered by Razer Chroma, this mouse features RGB lighting that can be customized to your liking with over 16.8 million color options. It's also equipped with nine programmable buttons which can be configured with Razer Synapse 3.
