Set the perfect mood with $50 off this Philips Hue White & Color Smart Bulb Starter Kit
Amazon is offering the Philips Hue White & Color 2-Bulb Starter Kit for $99.99, saving you $50 off the usual cost. This is the second-best price we've ever seen for them, coming in at just $20 more than the kit was on Black Friday.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
Smart bulbs are often the first step people take when creating a smart home, and for good reason. The bulbs are intuitive, easy to use, and actually save you money over time since they use so little energy. Setup is extremely simple. Just screw in the light bulbs, download the Philips Hue app, connect the included Bridge to your Wi-Fi network, and you're good to go. Choose from 16 million different colors plus a wide range of white shades, all with a few taps on your phone. For example, you could choose a fun color for party lighting, set your front porch lights to your team colors, or create the perfect environment for reading. You can also control the lights with your voice and something like Google Assistant or Alexa.
For more discounted Hue products, check out this LightStrip, which is currently $13 off. Don't forget to check back for more Prime Day smart home deals!
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
