Immerse yourself with the discounted Oculus Rift + Touch Virtual Reality System for $349
You are now subscribed
Your newsletter sign-up was successful
Amazon has the Oculus Rift + Touch virtual reality system on sale for $349 right now, saving you $50 off its regular price. This deal is a price match of the lowest it's ever been there, and is also available via Best Buy as an early Black Friday deal. It can regularly be found selling for $399.
This deal combines the Oculus Rift headset plus the touch controllers and sensors for a low-latency, immersive virtual reality experience. It's customizable and advanced, and it's designed to be easy to use even if it seems complicated. The set comes with six free games, including Robo Recall, Luckyʼs Tale, Quill, Medium, Dead and Buried, and Toybox. Other games are available for purchase through the Oculus Rift store. The headset is equipped with adjustable straps and a balanced weight that's comfortable to wear during longer listening periods.
You'll want to make sure your computer is up to spec before purchasing this bundle. It requires a graphics card such as a NVIDIA GTX 1050Ti, AMD Radeon RX 470 or greater and 8GB+ RAM, along with an internet connection and a Windows 10 PC. You'll need access to three USB 3.0 ports plus one USB 2.0 port and a compatible HDMI 1.3 video output as well. Best Buy's recommended specifications also suggest a CPU similar to or greater than an Intel i5-4590 or AMD Ryzen 5 1500X.
