Charge all your mobile devices with $7 off Nomad's durable 3-in-1 cable
If you're one of the many who's ended up with various mobile devices and tablets from different brands, you may find yourself occasionally wondering where your other charging cable went... With Nomad's 3-in-1 Universal Cable, there won't be any need to find another. This single USB cable features three separate connectors on one end, allowing you to plug it into Lightning, USB-C, or micro USB ports, and today you can save $7 off its usual price at Best Buy's eBay store. It regularly sells for $34.99 there — and more at Amazon — but is just $27.99 right now. That same price can be copped at the main Best Buy site, too.
This is technically a USB to micro USB cable with two durable connectors attached: Lightning and USB-C. The 1.5 meter long cable is made of braided ballistic nylon and has been flex tested to withstand over 10,000 bends, though it's important to note that it's not appropriate for high-speed USB 3.0 data transfers or high-voltage USB-C applications. Now you'll just want to make sure you have a USB wall charger or portable battery pack to use it with.
Of course, there are similar, slightly more affordable options like Anker's Powerline II cable, but it's pretty clear to see with just a glance at the difference between the two cables. Nomad's version is longer and much more durable so will likely have more longevity, and with today's deal it's not much more expensive either.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
