If your Wi-Fi connection seems to falter in certain rooms of your home, you could benefit from purchasing a mesh networking system. They utilize multiple access points for your devices to connect to the internet, and Woot has Netgear's tri-band Orbi Home Mesh Wi-Fi System on sale for just $289.99 today only. The three-piece system regularly sells for $350 at Amazon and is offered at Woot in new condition with a 1-year Netgear warranty. Shipping is free for Amazon Prime members.
Netgear CM1000 DOCSIS 3.1 cable modem
$129.99 $170.00 Save $40
Compatible with Comcast, Spectrum, Cox and most cable providers. Has DOCSIS 3.1 and supports up to 1 Gigabit internet speeds. Can work with any Wi-Fi router as well. Rental fees can cost up to $170 per year, so it pays for itself.
Netgear AX1800 Wi-Fi 6 4-stream wireless router
$66.21 $90.00 Save $24
Can handle speeds up to 1.8Gbps over wireless and works with Wi-Fi 6 devices like the iPhone 11 or Galaxy S10. Use the Nighthawk app for easy setup and management, including testing your internet speed and data usage.
Netgear Nighthawk MK62 AX1800 whole mesh Wi-Fi 6 system router and extender
$167.12 $200.00 Save $33
Includes one router and one satellite extender to cover up to 3,000 square feet in Wi-Fi. Get four powerful streams with speeds up to 1.8Gbps and reliable performance for more than 25 devices with MU-MIMO Smart Connect. Includes Ethernet ports.
$374.09 $499.99 Save $126
Netgear 16-port Gigabit Ethernet unmanaged switch
$156.06 $189.99 Save $34
The Orbi RBK52W mesh system is capable of covering up to 5,500 square feet with a strong wireless internet connection. It includes one AC3000 router and two AC2200 wall plug satellites to place in different areas of your home. Unlike other Wi-Fi sets that lose speed as you add devices, Orbi routers maintain data flow for your connected devices using a dedicated backhaul connection. Despite being three devices, the Orbi system operates under a single network name for a seamless connection.
Be an expert in 5 minutes
