Get $9 off a pair of well-rated Mpow over-ear headphones with this code
Amazon has the Mpow 059 Over-Ear Bluetooth Headphones on sale for $25.99 when you apply promo code MPOW059C during checkout. That code saves you $9 off the usual price. It only applies to the Black and Red colorway. Shipping is free, but you'll get your order faster with Amazon Prime. This price is better than any other price drop we've posted for them before.
Mpow X5 hybrid active noise-cancelling true wireless earbuds
$39.99 $60.00 Save $20
The hybrid active noise-cancellation on these earbuds uses an outward-facing mic to capture the bad noises and an inward mic to monitor the sound reaching your ears, then uses anti-noise to cancel out the bad stuff. Has 32-hour battery with the case.
Mpow MS1 in-Ear Bluetooth Earphones
$16.99 $29.99 Save $13
These true wireless earbuds come with a charging case that keeps them playing for up to 25 hours while you're on the go. There's also a built-in microphone and IPX7 waterproof nano-coating to keep them protected from runs in the rain and splashes.
Mpow H5 Active Noise Cancelling Over-Ear Bluetooth Headphones
$29.99 $49.99 Save $20
$33.73 $52.99 Save $19
$33.73 $53.99 Save $20
With 4.4 out of 5 stars from over 23,500 customer reviews, it's a safe bet that you'll get a ton of enjoyment out of these headphones. They feature high-fidelity stereo sound with passive noise isolation and a closed-back design to prevent sound bleeding that'll disturb your deskmates. They're also designed to stay comfortable. The ear cushions are soft and the padded headband won't squeeze your noggin. Use them wirelessly over Bluetooth all day thanks to the 20-hour battery life, or wire them up and listen for even longer. If your battery is low, you can charge the headphones for only 10 minutes to secure another two hours of listening time.
When you're done streaming BTS, fold the headphones down and stash them in the included case. Your purchase is backed by a 45-day money-back guarantee as well as a 24-month warranty.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
