Cut the cable company out of your life with the Mohu Sail HDTV Antenna at 50% off
After setting up an HD antenna in your home, there will be no looking back. It's simple and much more affordable than dealing with a cable company too, especially when you purchase one at a discount. One fine option on sale today is the Mohu Sail outdoor multi-directional antenna, available for just $59.99 via Best Buy's official eBay store and the main site. This offer is a one-day sale part of the site's Deals of the Day, meaning this opportunity will end later tonight. The Mohu Sail regularly sells up to $120 otherwise, so you don't want to let this deal pass you by.
The Sail comes with a 30-foot detachable cable, which gives you the freedom to put this antenna exactly where it needs to go. It also has a mounting kit to secure it in place. The four-in-one design means the Sail can go indoors or out, fit in the attic or on your rooftop or outdoor siding, or go just about anywhere else. It delivers a clear signal and has a reception range of up to 75 miles. Use a reception map to see how effective this antenna will be based on your location.
