Light up any room using your voice or an app and this discounted LED light strip for $24
You are now subscribed
Your newsletter sign-up was successful
One easy way to change up any room's look is with an LED light strip, and Minger makes some of the most highly-reviewed models on Amazon which offer features like app control, music synchronization, and Alexa voice control compatibility. The DreamColor 16.4-foot LED Light Strip is one option that includes all of those and more, and today you can snag it for just $23.99 when you enter promo code 8YKSW2SV during checkout. That saves you $16 off its regular price and drops it back to one of its best prices in history.
This 16.4-foot light strip is one of Minger's most fully featured options, with the ability to be controlled using an app or with your voice and an Alexa-compatible device like the Echo Dot. It can even sync to the beat of your music.
$23.99 $39.99 $16 Off
This LED light strip features an adhesive backing that makes it stick easily to wherever you've decided to install it. Once set up, you'll be able to use the Govee Home app on your smartphone to change its color, schedule when it's on or off, and more from anywhere in the world. If you have an Amazon Alexa device at home, like the Echo Dot, you can begin voice controlling this light, or maybe even set it up to change with the beat of the music you're listening to. It can fit in so many places too, from behind your TV to in the garage, a bedroom, or your office.
If you're not interested in this light strip's app functionality, there's an even more affordable version of this strip that is controlled with an included IR remote and falls to $11.99 when you use code 8UN8ZNDA during checkout. It's the same length at 16.4 feet though it's missing a few other features that the model above includes such as Alexa compatibility.
Unlike the model above, this product doesn't include app functionality, Alexa compatibility, or music synchronization. However, it does come with an IR remote that lets you change between tons of different colors just as easily and for less than half the price.
$11.99 $19.99 $8 Off
Minger even has a light strip that uses a cigarette lighter plug to power up, making it a perfect pick to use in your vehicle, and you can snag one today for only $9.34 when you enter code I7WMP867 during checkout. That's a discount of $7 off its regular price, and it comes in four pieces to make installation a bit simpler no matter which vehicle you own.
