The Minger DreamColor 16.4-foot Wi-Fi LED light strip drops to $23.99 with code OLUVMRCM on Amazon. That's down from a street price of $40 which it has never dropped from without a special coupon. These DreamColor lights are already more affordable than the likes of Philips Hue, but are a steal at $24.
This light strip connects with an app on your phone so you can change its color, schedule its usage, and more from anywhere in the world. It can sync with the beat of your music too, though you'll need to use code OLUVMRCM during checkout to snag this low price.
$23.99 $39.99 $16 off
This strip has RGB LEDs covering 16.4 feet. It has physical controls for determining brightness and colors, or you can use the accompanying app from afar. If you're already set up with some Amazon Echo devices, you can use these to adjust your lights with just your voice. The strip has a high-sensitivity mic that can adjust the speed and color of the lights automatically based on ambient sound so your strip lighting will sync with your favorite music. The lights are also waterproof so they can be used inside your home as well as outdoors. Users give these lights 4 stars based on nearly 100 reviews.
Be an expert in 5 minutes
