Gain smart control outside with Meross' Dual Outdoor Smart Plug at 33% off
Having a smart home is cool and all, but what about all of your outdoor appliances? They deserve some love too, which is why you need to pick up the Meross MSS620 Dual Outdoor/Indoor Smart Plug. It's down to $17.99 at Woot for today only. At Amazon, it regularly sells for around $27 on average. Don't forget to use your Amazon Prime account to save on shipping, too.
Meross dual outlet smart plug 2-pack
$25.99 $34.00 Save $8
Create two outlets with one plug and a compact design that won't block the other socket. Control the plugs and the devices plugged into them with the Meross app. Or use Apple HomeKit, Amazon Alexa, or Google Assistant for voice control.
Meross dimmable multi-color Wi-Fi smart table lamp
$26.99 $45.00 Save $18
The intuitive touch controls on top let you change the color, adjust the brightness, and turn it on or off. Also works with Siri, Alexa, and Google Assistant for voice control. Includes several levels of tunable white and 16 million colors.
Meross Smart Wi-Fi Garage Door Opener
$26.79 $40.00 Save $13
Combine the code with the $10 off on-page coupon for maximum savings. Adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub. Easy to set up with included tools. Get notifications and reminders.
Meross smart Wi-Fi garage door opener remote
$26.79 $39.99 Save $13
This garage door opener lets you control it using an app on your phone, or even with your voice and a compatible voice assistant like Amazon Alexa. Clip the coupon on its product page and use the following promo code to save $13 at checkout.
Smart Garage Door Opener Remote, APP Control, Compatible with Alexa and google Assistant, Multiple Notification Modes, No Hub Needed by meross - Upgrade Version
$49.99 $59.99 Save $10
This IP44 waterproof smart plug is equipped with two grounded AC outlets and works just like indoor-only smart plugs; you can control it using a free app on your iOS or Android device from anywhere in the world, or voice control it using a device such as the Echo Dot or Google Home Mini. Both outlets are capable of being controlled separately or as a pair, too. Using the app, you can even set daily timers or schedule the outlets to come on as needed. It supports IFTTT as well, with Samsung SmartThings and NEST compatibility coming soon.
Almost 600 customers at Amazon left a review for this smart plug resulting in a rating of 4 out of 5 stars. An extension cord might make for a good addition to your order today, too.
