This discounted 2-in-1 flash drive can connect via USB or USB-C for just $6
Transferring files between different devices can be quite a pain, but the MECO 2-in-1 USB-C + USB 3.0 Dual 32GB Flash Drive makes things much easier. Today you can snag one at Amazon for only $6.49 when you enter promo code S64IQQ86 during checkout. That'll save you 50% off its regular price, and it's also the lowest we've ever seen this product reach.
Meco 7-in-1 adapter USB-C hub
$16.42 $29.99 Save $14
$1.01 $35.99 Save $35
$1.21 $36.99 Save $36
MECO Wireless Battery-Powered 1080p Camera
$49.59 $79.99 Save $30
Place this camera anywhere indoors or outside. Use it to survey your property, communicate to visitors, and more.
This 2-in-1 USB flash drive is equipped with two different connectors: USB 3.0 and USB Type-C 3.1. That means you can plug it into your computer, move a file onto it, then plug it into your phone and move that same file to your device. It works in reverse to free up space on your smartphone easily too. It features read speeds up to 130MB/s while its metal casing keep your files protected from the real world, as it's waterproof, shockproof, magnet-proof, and scratchproof. MECO includes a one-year warranty with its purchase.
