Switch between computers with Logitech's MX Master mouse discounted to $47 today only
Logitech's MX Master wireless mouse is one of the most versatile you can find as it has the ability to connect with up to three different Windows or Mac computers using either Bluetooth or the included USB receiver. With a press of a button, you can switch between the device you have connected easily, and it tracks nearly anywhere — even on glass. Though it usually sells for around $60, Amazon's sale on Logitech PC gear discounted its price to $47 for just one day only. It's also a price-match of the lowest it's ever reached there.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
This wireless mouse features a dark field sensor that allows it to track extremely well, no matter where you're using it. Not only is there a sensitive, speed-adaptive scroll wheel, but another, unique thumb wheel which allows for some advanced gestures as well as horizontal navigation. With its advanced power management, the MX Master can eek out up to 40 days of power on a single charge or power up for a full day's work within just four minutes.
Aukey's XXL Gaming Mouse Pad would be a great addition to today's order if you don't have a mouse pad at home already... especially considering you can grab it at 50% off today.
At Amazon, nearly 5,000 customers have left reviews for the MX Master mouse, resulting in a rating of 4 out of 5 stars. For more great Logitech deals, be sure to view the full sale before it comes to an end tonight.
Be an expert in 5 minutes
