Logitech's refurb Harmony Elite Remote on sale for $150 lets Alexa take control of your gadgets
Logitech's Harmony Elite Remote Control is one of the most advanced remotes out there. Not only does it combine your existing remotes into one, but it also adds a ton of extra functionality that you won't find in most others, and today only you can snag one for just $149.99 at Woot in factory refurbished condition. While it won't be brand new, these have been tested and ensured to be in working condition directly by Logitech. Plus, if you have any issues with the remote you receive, you have 90 days to return it.
Woot charges $6 for shipping, but you can score free shipping by logging in with your Amazon Prime account. If you don't have one yet, starting a free 30-day trial can earn you the free shipping as well as entry into next month's huge Prime Day sale.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
The Harmony Elite kit has an all-in-one remote control that can tame up to 15 entertainment and connected home devices, featuring a full-color touchscreen with the ability to easily swipe and tap to control channels, adjust volume, personalize your favorites, and communicate with smart home devices. You can set up one-touch activities like "Watch a Movie" to power on and off and switch between the right devices. You can also download the Harmony app and use your smartphone or tablet as a universal remote.
It's also Alexa compatible, which means you can use Alexa voice commands to do multiple activities on the remote at once, like turn on the TV, change the input, turn on the DVD player, and even change the colors of your lights with just one phrase, though you'll need a device like the Echo Dot speaker to do so. It can be controlled through closed cabinets thanks to its IR mini-blasters, and the included charging station means that you won't have to worry about swapping out batteries. This has sold for as much as $350 in the past but more often sells for around $260 on average at Amazon.
