Control 15 different devices at once with the Logitech Harmony 950 remote back at its Black Friday price
The Logitech Harmony 950 touch infrared remote control is down to $149.99 on Amazon. This is a record-equalling low price for the Harmony 950 matching a price we've seen just once before on Black Friday. The remote normally sells for around $200 these days and we don't know how long this deal will last. Shipping times are already slipping, so get your order in while you can.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
The all-in-one remote features a 2.4-inch touchscreen with settings that allow you to power on and off multiple devices in a single touch. It comes with a charging station to keep it powered up and is compatible with over 270,000 devices. You'll be able to control your TV, cable box, Apple TV, Blu-ray player, and even your game console all with this one remote; it can be connected to up to 15 devices simultaneously, so you don't have to go digging for that lost controller.
