Connect to 4K displays and more with this 5-in-1 USB-C Hub for less than $13
Having all the ports to connect devices like monitors and mice and keyboards to your computer is nearly impossible these days without having a USB hub handy. If you're in need of a way to keep more connected at once, consider picking up the LINKWIN USB-C Hub Adapter at Amazon. This 5-in-1 hub normally sells for up to $25, but by entering promo code OGVJQQAI during checkout, you can grab one for only $12.50.
This USB-C hub by LINKWIN is equipped with an HDMI port that supports 4K UHD resolution, along with two USB 3.0 ports, an SD card slot and a microSD/TF card slot. With the HDMI port, you'll be able to mirror whatever's on your computer to an external monitor or even your TV using an HDMI cable, while the dual USB 3.0 ports allow for data transfer speeds up to 5Gbps. You can also insert a micro SD card to access its files on your computer directly.
So far, only a small group of customers have left reviews for this product, but it's doing well at the moment with a rating of 4.4 out of 5 stars based on 27 reviews.
Be an expert in 5 minutes
