Get more done with Lenovo's 6-in-1 USB-C hub on sale for $36
The grey Lenovo 6-in-1 USB-C aluminum hub and adapter is down to $35.74 with code 35M7ZEDS on Amazon. This hub has been selling for around $55 since last year, and we haven't seen it drop lower than that price directly. The same code works on Silver as well as Grey.
The code works in Silver or Grey. The price is one of the best we've seen.
$35.74 $55 $19 Off
The hub will turn one USB-C port into half a dozen different functional ports, including HDMI, a Gigabit Ethernet port, a USB-C charging port, two USB 3.0 ports, and an SD card reader. The 4K HDMI output gives you a way to connect your computer to a high-resolution display and share your screen with crystal clear images. Forget Wi-Fi and establish a more stable internet with the Gigabit Ethernet port that adapts to networks up to 1002 Mbps. The USB ports can all be used for storage or data transmission, and you can use the USB-C port to charge. Users give this hub 4.4 stars based on 261 reviews.
Be an expert in 5 minutes
