Snag an ultra-durable Lecone USB-C Charging Cable for just $6
Amazon is offering this Lecone USB-C to USB-C Charging Cable for only $6.49 when you clip the 10% off coupon located on the product page and apply code A5JMXBZY during checkout. That nabs you half off the usual $13 price, and so far the reviews are positive.
If lots of your gear uses USB-C, this cable is definitely worth picking up while it's this inexpensive. Make sure to use code A5JMXBZY to get your discount.
$6.49 $13 $7 Off
This 5A cable supports Power Delivery up to 100W, 4K video, and rapid data transfer. It will intelligently adjust speeds to charge your gear as quickly and safely as possible, and the nylon braided exterior prevents fraying and tangles. The cable measures 2.6 feet long. If you need more length, check out this Anker option.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
