Grab a $25 gift card with the discounted Jabra Elite Active 65t true wireless earbuds
The Jabra Elite Active 65t true wireless earbuds dropped to around $150 at most retailers recently, including Newegg and Amazon. Right now Newegg Flash is sweetening the pot on the red version of the earbuds by adding a $25 gift card with your purchase.
Jabra Evolve 75 Bluetooth headset for the office
Latest Videos From
$216.80 $280.00 Save $63
The headset produces incredible audio with world-class speakers and has crystal clear voice communication, too. Advanced mics use active noise cancellation to keep your calls clear and the ambient noise gone. Lasts up to 30 hours.
Jabra Elite Active 65t true wireless earbuds titanium black
$69.99 $100.00 Save $30
The earbuds have Bluetooth, up to 5 hours of battery on a single charge, and up to 15 hours total using the charging case. Also rated against sweat and dust. Work with voice assistants. This price available in three different colors.
Jabra Elite 65t true wireless earbuds titanium black best buy
$49.99 $80.00 Save $30
The 65t have dual mics and true wireless Bluetooth stability that helps reduce audio drops. They will last up to 5 hours on a single charge of the battery with an extra 10 hours from the charging case. Also available at Best Buy.
Jabra Elite 65t true wireless earbuds titanium black headphones
$64.99 $80.00 Save $15
Five hours of battery life plus up to 15 hours with the charging case. Four mics help reduce noise and wind when taking calls. Passive noise cancellation to block unwanted sound. IP55 rating resists dust and water. Connect to voice assistants.
Jabra Elite 75t active noise-cancelling true wireless earbuds
$119.99 $150.00 Save $30
Active noise-cancelling filters out the world. Includes 4-mic call tech that helps eliminate wind and noise. You get 7.5 hours of battery life per bud with a total of 28 hours using the charging case. Has customizable equalizer and no audio dropouts.
If you don't like Red or you don't mind going refurbished, you can get the black version refurbished for $99.99, and it also comes with a $10 gift card.
The Elite Active 65t are similar to their (usually) slightly cheaper counterpart Elite 65t model but, as the name suggests, add some sportier features for those looking for workout headphones. As well as dual mics and support for Google Assitant, Alexa or Siri, the Actives add a slightly grippier finish, IP56 water resistance (versus IP55 for the standard Elite 65t), a built-in accelerometer for motion tracking and a quick charge feature giving you 1.5 hours of usage from a 15-minute charge in the included charging case. These headphones are covered by a 180-day warranty from Jabra.
