Turn one outlet into four with this discounted iClever USB Wall Charger
Charging multiple devices can be tricky. When your phone, tablet, smartwatch, and on-the-go console all use different cords, it's annoying to prioritize their charging needs. Take care of the issue with the iClever 4-Port USB Wall Charger on sale for $14.99. Simply clip the on-page 5% off coupon and enter code XUAN1599 during checkout to get in on this price, which saves you $5 off the normal cost.
This well-rated charging station has SmartID technology built in, which provides optimal speeds to all of your devices, up to 2.4 amps per port. There are safeguards against short-circuiting, overheating, and overcharging, too. The plug folds down for easy transportation as well. The manufacturer backs this product with an 18-month warranty and a 30-day money-back guarantee.
It's worth noting that the iClever charger does not support Qualcomm Quick Charge 3.0. If you're looking for a speedy wall charger that does, it's worth checking out the discounted AMLINK 40W USB Wall Charger. It has three USB-A ports, one of which is QC 3.0-enabled, as well as a USB-C port. It currently has an on-page coupon that will save you a couple of bucks, too.
