Achieve a sleek dual display for less than $26 with HUANUO's adjustable monitor stand
Raising your monitors off your desk can offer quite a bit more space to get your work finished, and there are plenty of affordable monitor stands to help make that happen. One such product is the well-reviewed HUANUO Adjustable Dual Monitor Stand, which features dual monitor arms capable of holding most 13 to 27-inch LCD computer monitors with a VESA pattern of 75x75mm or 100x100mm. It's even available at a discount when you enter promo code U6YUWNVH during checkout; that'll save you $10 off its regular price and bring its cost down to just $25.99.
This height-adjustable monitor stand allows you to swivel its arms and the VESA plate, allowing you to move your monitors in a myriad of ways including placing them into portrait mode. The stand is constructed with a solid steel pole and a heavy-duty base, with each arm capable of holding up to 22 pounds safely. Plus, everything you'll need for setup is included with your purchase, along with a two-year warranty from HUANUO.
If this stand isn't the right match for your desk, there are a few others on sale today only at Woot.
