Add a Fire Stick 4K and Echo Dot 3rd-gen to your home at $30 off
In case you haven't heard, Amazon is running a massive Father's Day sale, offering deals on all sorts of its devices. One such deal brings this Fire TV Stick 4K and Echo Dot Bundle down to $69.98, which is $30 off the usual cost and the best price we've seen for it since Black Friday.
These are arguably two of the most commonly used smart home gadgets, and this price is the best since Black Friday.
$70 $100 $30 Off
The Fire TV Stick 4K is a powerful little gadget that's simple to use. It allows you to stream from Netflix, Prime Video, Hulu, and more. There are dedicated buttons to help you control the volume and power on your compatible TV, and using the Alexa Voice Remote, all you need to do is say the word to start a show, change the volume, and more.
You'll also get a third-generation Echo Dot, a smart speaker that can do much more than play your music. Check the weather. Control smart home appliances. Set timers and alarms. Make shopping lists. All of it with just a few spoken words and a Wi-Fi network.
This bundle is a super easy way to smarten up your living room, and today's price is the best we've seen in months. However, the deal price is only around for a limited time, so be sure to shop sooner rather than later if you're interested.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
