The all-new Ecobee Smart Thermostat is already down to just $235
In case you haven't heard, there's a new Ecobee Smart Thermostat on the block. First released in early June, it usually sells for $249, and while we've seen a couple of insignificant price drops, it just hit an all-time low of $235. That's 5% off the usual cost. Shipping is free with Amazon Prime, and your membership will also get you access to Amazon Prime Day next month.
Ecobee Switch+ smart light switch white
$39.99 $80.00 Save $40
The switch icludes built-in motion detection, ambient light sensors, and built-in Amazon Alexa. It's easy to install and gives you control over the switch from anywhere using the mobile app or even your voice. Pairs nicely with the smart thermostat.
$79.99 $99.99 Save $20
This indoor Wi-Fi camera streams continuously in 1080p HD so you can always check in on what's happening using an app on your phone. It sends your phone notifications when motion is detected or even if your smoke alarm is set off.
Ecobee Switch+ smart light switch with Ecobee Smart Thermostat with voice control
An $80 value
Ecobee Smart Thermostat with voice control and room sensor
$199.00 $249.00 Save $50
You can use the smart sensor to help you find the perfect temperature for the important rooms in your home. The thermostat has dual-band Wi-Fi, far-field voice recognition, a touch display, and the ability to work with all smart homes.
Ecobee4 smart thermostat with room sensor woot
$149.99 $220.00 Save $70
This is one of the best smart thermostats around with Amazon Alexa built right in and compatibility with Google Assistant and Apple HomeKit. Works with most residential systems. Use Amazon Prime to avoid the shipping fee and save a few bucks more.
This luxe thermostat features a glass finish, touch display, far-field voice recognition, and more. It also comes with a Smart Sensor, which keeps important rooms comfortable based on both occupancy and temperature. Having a smart thermostat can actually save you money over time. For instance, it can lower the temperature at night, or keep your house warmer when you aren't home.
The thermostat also features Alexa voice control built right in, so a few spoken words can adjust the temperature of your home. That functionality offers you a slew of Alexa skills, like music playback, weather forecasts, and drop-in calling. You can control it via the free app for iOS and Android, too. Installation takes 45 minutes or less, and the thermostat also plays nicely with Google Assistant, HomeKit, SmartThings, IFTTT, and more.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
