Make your Ecobee thermostat even smarter with these discounted sensors
Amazon is offering two Ecobee Smart Sensors for $53.99 today, saving you $25 off the usual cost. This is the best deal we've seen for the newly-released two-pack, which has positive customer reviews so far. Today's price beats one we saw a couple of weeks ago by $10.
Ecobee Switch+ smart light switch white
$39.99 $80.00 Save $40
The switch icludes built-in motion detection, ambient light sensors, and built-in Amazon Alexa. It's easy to install and gives you control over the switch from anywhere using the mobile app or even your voice. Pairs nicely with the smart thermostat.
Ecobee SmartCamera
Ecobee SmartCamera
$79.99 $99.99 Save $20
This indoor Wi-Fi camera streams continuously in 1080p HD so you can always check in on what's happening using an app on your phone. It sends your phone notifications when motion is detected or even if your smoke alarm is set off.
Ecobee Switch+ smart light switch with Ecobee Smart Thermostat with voice control
An $80 value
Ecobee Smart Thermostat with voice control and room sensor
$199.00 $249.00 Save $50
You can use the smart sensor to help you find the perfect temperature for the important rooms in your home. The thermostat has dual-band Wi-Fi, far-field voice recognition, a touch display, and the ability to work with all smart homes.
Ecobee4 smart thermostat with room sensor woot
$149.99 $220.00 Save $70
This is one of the best smart thermostats around with Amazon Alexa built right in and compatibility with Google Assistant and Apple HomeKit. Works with most residential systems. Use Amazon Prime to avoid the shipping fee and save a few bucks more.
These smart sensors work with all Ecobee smart thermostats. They have built-in occupancy sensors which help your thermostat pay attention to rooms that matter and ensure that your entire home has an even temperature. For instance, if your bedroom tends to get warm at night, you can place a sensor in the room and your thermostat will keep the temperature lower. Alternatively, if there are specific rooms of the house that you don't use very often, or you just don't want to waste energy while you're not home, a sensor can help your thermostat avoid excess heating or cooling in unoccupied spaces. That means more money shaved off your power bill. Activation takes just a few seconds as well.
If you don't have an Ecobee thermostat yet, this model is on sale.
Louryn Strampe
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
