Combine the Ecobee4 smart thermostat with two room sensors in this bundle down to $216
At Home Depot, you can grab the Ecobee4 smart thermostat bundled with two room sensors for $216 total. The smart thermostat normally sells for $249 by itself, even though it is currently discounted to $199 on Amazon. The room sensors go for $74 alone. That means you're saving more than $100 with this bundle.
This thermostat is easy to install and even easier to use. You can control it with just your voice or through the free ecobee iOS and Android app, and the included room sensor helps keep an even temperature throughout your whole house. If you're looking to save a few bucks while keeping your house cool or hot, this is a perfect way to do it. You'll also save some money on your annual heating and cooling bills, meaning the thermostat will end up paying for itself. Be sure to grab one now, before you miss out on the savings.
These room sensors help detect occupancy in a room and the temperature of the room to help keep it comfortable and even across your whole home. Since this is a 2-pack, that means you'll be able to add these in two additional rooms of your home which may not always feel as warm or cool as the others and help keep them a bit more even.
