Keep up with your teammates with Dell's 24-inch 144 Hz monitor on sale for $150
Dell's S2419HGF 24-inch 144 Hz FreeSync 1080p gaming monitor has dropped to $149.99 at Amazon. This is a price match of a similar deal at Walmart and matches one we saw in early May that has since expired. The next best price these days is over $218 at Dell. It was selling as high as $230 in February.
This is a relatively new monitor from Dell on Amazon. It uses a TN panel to get you really fast 1ms response times and a 120 Hz refresh rate overclocked to 144 Hz. The FreeSync tech helps reduce screen tearing while gaming, and the pixel resolution is 1920 x 1080. The connectivity options include HDMI and VGA. You'll also get a three-year warranty from Dell. The monitor is also certified to work with Nvidia's G-Sync if you use a DisplayPort connection.
