Travel with your tech easily thanks to this $7 Bestek Travel Power Adapter
Amazon is offering 30% off this Bestek Travel Power Adapter when you click this link and add the item to your cart. The price will fall from $9.99 to $6.99, the lowest in its history. No coupon code is required to get your discount. So far, customers have left 115 reviews, resulting in a rating of 4.2 out of 5 stars.
No coupon code is needed to get the best price yet on this travel adapter, which will have your back in over 150 countries.
$6.99 $9.99 30% Off
This has three USB smart charging ports as well as an AC socket. It'll work in Europe, the UK, Australia, and the United States. It's compact, with a foldable plug, and safely delivers power as quickly as possible up to 2.4A per port without overloading or overheating your tech.
Note that it is not a voltage converter. If you're looking to use something like a hair dryer, that's what you'll need. This option should work nicely.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
