Spruce up your vehicle by saving on an Aukey Dual-Port USB-C PD Car Charger
You should never use your phone while driving, but that doesn't change the fact that you may have it on deck for playing music or getting directions. That means you'll want to ensure that the battery lasts, which is why it's smart to have something like the Aukey USB-C PD Dual-Port Car Charger around. Usually it costs $20, but today you can snag one for $15.99 when you apply code U6AJHIUX during checkout at Amazon. This price drop is the best we've seen for this particular model, which has favorable reviews so far.
Thanks to the coupon code below, you can save big and easily charge two devices at once.
$16 $20 $4 Off
This compact charger features Power Delivery and Quick Charge 3.0, with up to 21W outputs to charge your devices quickly and efficiently. There's a USB-C port and a USB-A port, meaning every device you own should work perfectly with the charger. You can also use it to charge two devices simultaneously. The device has a tiny footprint and will likely look like it's built in to your car's lighter outlet, and there are built-in safeguards to protect against overheating, excessive current, and overcharging. Aukey backs your purchase with a two-year warranty.
Need an extra charging cable? This one is compatible with three types of devices and the price isn't too shabby either.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
