Manage multiple SD and micro SD cards with Aukey's USB-C reader on sale for $8
You are now subscribed
Your newsletter sign-up was successful
The Aukey dual-slot SD microSD USB-C card reader is down to $8.39 with code EPSV44YJ on Amazon. The card reader goes for $12 without the code and often sells around $15. This is the lowest price we've seen.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
Not only can this adapter read both SD and microSD cards, it can do it at the same time. Maximize your data transfer with speeds up to 5 Gbps. It's a plug-and-play device that requires no software or drivers. The compact and lightweight design means you can slip it in your backpack or photography bag and use it anywhere. It also comes with a two-year warranty. Users give it 4.3 stars based on 25 reviews.
The reader can handle any card of any capacity up to 2 TB, so you should stock up on a few big ones.
