Secure your phone in the car with Aukey's suction mount for 50% off
Driving around with your phone in your hand is not only dangerous but might be illegal in your state too. If it hasn't caused you trouble already, the day is surely coming. Save yourself the hassle of getting a ticket or into an accident with one of Aukey's car phone mounts. Using code MZI5UPDA at Amazon will bring its price down to just $4.99, saving you 50% in the process. That also matches the best deal we've ever seen on this mount.
Keeping your hands on the wheel and off your phone while driving is a lot easier with one of these phone mounts, and today entering the code below will save you 50% off its price.
$4.99 $9.99 $5 Off
The mount uses a reinforced suction mount to adhere itself quickly and easily to multiple surfaces, including the windshield or dashboard of your car. You could also use it outside the car to elevate your phone on a nightstand or your desk. The 360-degree ball joint design helps you rotate the mount so you can find the best possible viewing angle. The cradle can hold smartphones between 4 and 6.5 inches wide. If you need to move the mount, you can easily remove it and wash the suction cup and start over somewhere new.
Aukey backs it up with a two-year warranty. Users give it 4.1 stars based on 189 reviews.
Be an expert in 5 minutes
