The AUKEY Powered 10-Port USB Hub is a desk essential at 50% off
Modern computers are extra sleek, but unfortunately, that often means you have less ports to work with. Aukey's 10-port Powered USB Hub can help solve your problem. Though it's currently priced at $42, using coupon code 5FLUTQCV at Amazon will discount its price down to $20.99. That's over half off the normal cost and a match of the lowest price we've seen for this model.
By plugging this single device into a USB-A port on your laptop or computer, you'll instantly gain access to seven USB 3.0 data ports with transfer speeds of up to 5Gbps, along with two AiPower adaptive charging ports and a single Quick Charge 3.0 port. You'll want to be aware that the data ports can't charge, while the charging ports can't transfer data.
Best of all, there's no setup required. You simply plug in the hub and begin using it. It's compatible with Windows and Mac and comes with a 12V power adapter, along with a 2-year product replacement warranty. There are safeguards built in to protect your gear as well. At Amazon, 28 customers reviewed the hub resulting in a rating of 4 out of 5 stars.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
