Add another Arlo Pro wireless security camera to your home system at its best price yet
If you already own one of the Arlo Pro camera kits, but you need just a bit more coverage around your home, you can get an add-on camera at its best price ever right now. The Arlo Pro rechargeable wireless HD security camera is down to $104.99 on Amazon. This camera was selling for around $140 recently and hasn't ever been priced this low until today.
You won't be able to use this just by itself because it needs the base station that's included with the Arlo Pro kits. If you don't have the base station, you'll want to look into buying an Arlo Pro system.
The Arlo Pro camera is 100% wire-free, weather-resistant, and outfitted with a rechargeable fast-charging battery. It has two-way audio thanks to a built-in mic and speaker. You can even use this camera with voice control systems like Alexa and Google Assistant, though you'd need a compatible device like the Echo Dot.
