Anker's two-piece PowerPort wireless charging bundle hits a new low price for one day only
Thanks to Anker's huge tech essentials sale going on at Amazon today only, you can begin wireless charging with the popular PowerPort Wireless 5 Pad and Stand bundled together for only $29.99. With today's 25% discount, you'll be saving $10 off the regular cost and snag this combo pair at the lowest price ever offered.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
With this PowerPort double pack, you'll be able to have two wireless charging stations set up at your home. The wireless charging pad is perfect to keep by your bedside, charging Qi-compatible devices at up to 5W. Meanwhile, the wireless charging stand is more suitable for your desk as it keeps your phone propped up so you can continue using it while it's powering up. Aukey includes two 3-foot micro USB cables with today's purchase, though you won't receive any wall chargers with the set. Luckily, you can find some in Anker's sale today at a discount as well. Anker also includes an 18-month warranty with purchase of these wireless chargers.
Over 100 Amazon customers have left reviews for this set resulting in a rating of 4.3 out of 5 stars.
