Add three helpful ports to your computer with Anker's USB-C Power Delivery hub at 20% off
Connecting your computer to your TV so you can use it as a large monitor can unlock a ton of possibilities, but since most computers aren't built with HDMI ports these days, you'll need something other than just a cable to connect the two. Luckily, the new Anker 3-in-1 USB-C hub with Power Delivery is perfect for the job and already on sale at 20% off via Amazon when you enter code ANKER8337 during checkout. That brings its price down to $20.79 from its regular cost of $26.
Plug this adapter into the USB-C port on your MacBook, Chromebook, Dell XPS, or other device and you've got three new functions to work with. The hub adds a USB-C port with 60W Power Delivery and charging pass-through, a USB-A 3.0 port for connecting older devices with transfer speeds up to 5 Gbps, and 4K 30Hz video through the high-speed HDMI port. It also comes with an 18-month warranty from Anker.
