Get your sweat on with Anker's Soundcore Spirit Bluetooth headphones on sale for $23
Soundore Anker Spirit Pro GVA earbuds
Soundore Anker Spirit Pro GVA earbuds (Image credit: Soundcore)
The Anker Soundcore Spirit sports Bluetooth headphones have dropped to $22.99 on Amazon when you clip the on-page coupon. Only the black color is on sale for this low, though the others are just a couple of bucks more if you find them more fetching. These normally sell for $33. Today's deal beats all of the ones we've posted previously for these headphones.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The headphones are IPX7 rated, which means they use sweat-proof technology and can even withstand rain. They use premium composite drivers for crystal-clear sound. The cable clip helps keep the neckband off your neck, and you'll be able to find the perfect fit using the included ear tips. The eight-hour playtime means you won't run out of battery in the middle of your workout (unless you're a machine), and it comes with a travel pouch. Anker backs them up with an 18-month warranty.
In the market for more discounted tech? Prime Day is just around the corner, and we hope to see more products from Anker featured in that sale.
