Bluetooth connectivity in your vehicle is one $11 device away from reality
You don't have to buy a whole new car or an expensive stereo system to start using Bluetooth in your vehicle. Anker's SmartCharge F0 Bluetooth FM Transmitter is on sale for just $10.99 at Amazon when you clip the coupon on its product page and then enter promo code ROAVFB22. That'll save you around $6 off its regular price, and a lot more compared to those other methods of wirelessly connecting.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This device plugs into your vehicle's cigarette lighter to power up and includes two integrated USB ports to make it easier to charge your phone while traveling. Once powered up, you can pair your phone to it using Bluetooth and then select an unoccupied radio station. Using a boosted FM signal and static-cancellation technology, the transmitter sends your music to the radio station so you can listen wirelessly. It features Bluetooth 4.2 and even comes with a one-year warranty.
There are a few vehicles which this device is incompatible with, so be sure to check the provided list on Amazon's product page before your purchase.
