Quick charge your smartphone with the 2-port Anker Roav Spectrum on sale for $14
Get the Anker Roav SmartCharge Spectrum 30W dual-USB Quick Charge 3.0 car charger down to $13.99 when you clip the $2 off on-page coupon and use code ROAVBB44 during checkout at Amazon. The car charger normally sells for $20 and has never dropped this low directly.
What really makes this car charger unique is its support for Quick Charge 3.0. Not a lot of car chargers do that, so if you have a phone that uses Quick Charge technology then you can get an even faster charge using the Spectrum. Even if you don't, the PowerIQ technology helps the charger identify what's plugged in and deliver the fastest possible charge. You can also use the Roav Charger app to record your car's location and pin it on a map, helping you find your car in crowded parking lots. The LED ring can also be adjusted in tone and hue using the app and the 16,000 color options. Anker backs it up with an 18-month warranty. Users give it 4.3 stars based on 340 reviews.
