Save $20 on an Anker Roav Jump Starter today only at Woot
Woot is running a one-day sale on Anker Roav Jump Starters that could help you out in a pinch this summer. Both the 400A and 800A Pro models are on sale with $20 off their usual prices making them an easy pick up for your glove box. Shipping is free for Amazon Prime members.
Keep an 800A or 400A jump starter in your trunk and a dead battery won't leave you stranded. Today you can snag either of them at $20 off.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Roav 800A 8000mAh Jump Starter Pro is suitable for gas engines up to 6L or diesel engines up to 3L and powerful enough to start them up to 15 times on a single charge. There's a built-in battery monitor that can give you an instant readout of your vehicle's battery status, along with a high-intensity LED lamp, two high-speed USB ports that can help charge your phone and other devices, and even an integrated compass. There are also protections against reversed connections, back flushing, low voltage, and overheating. You'd usually pay $100 for it.
You can also get the Anker Roav 400A Jump Starter on sale at $59.99. It has a much smaller jump starter but the portable battery is a tad bigger at 9000mAh. It regularly sells for $80 at Amazon.
Anker includes a one-year warranty with your purchase, as well as a carrying case and a USB charging cable. You will need a USB wall adapter or a car charger to keep it powered up, so maybe pick one of those up with the money you saved.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
