Anker's Roav HydroClean electric pressure washer is nearly $40 off today only
If the outside of your home is in need of a little TLC, Amazon has a one-day deal you should seriously consider. Anker's Roav HydroClean electric pressure washer is down to $112.49 today only, marking a new low price. This pressure washer regularly sells for $150 and originally debuted at $200.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This deal is part of a larger one-day sale on Anker accessories and tools, which includes discounts on car chargers, USB cables, and more.
The Roav HydroClean features an 1800W motor that can blast out 1.78 gallons per minute of water at 2100 psi. It comes with three nozzles to adjust its spray, along with a 26-foot long high-pressure hose and an extender wand. It's equipped with a 35-foot long cable too, though you may want to order an extension cord to use with it.
Anker includes a one-year warranty in case you experience any issues with this purchase.
