The Anker Roav 1080p Dash Cam on sale for $100 records both inside and outside your car
The Anker Roav DashCam Duo 1080p GPS dash cam falls to $99.99 on Amazon when you clip the coupon on its product page. It takes $30 off its $130 street price and drops it back down to the lowest it has ever gone.
It's called the Duo because it has a front facing and interior facing camera, which simultaneously capture what's going on on the road ahead of you and what's happening in the vehicle's interior. Both cameras capture footage in 1080p. They have dual 323 Sony sensors and NightHawk Vision technology that help capture footage with enhanced night vision. The built-in GPS will automatically record your driving route, location, and speed so you have all that information when you need it. The cam can also keep an eye on your vehicle for 24 hours a day with a built-in gravity sensor to activate when it detects movement. It's also covered by a one-year warranty.
You'll record all the footage onto a microSD card, so grab one from Samsung that can handle a lot.
