Anker's discounted 30W PowerPort Atom III USB-C Charger is a great fit for tight spaces
As the company's slimmest USB-C charger so far, the Anker PowerPort Atom III 30W USB-C Charger is a perfect fit for using with power outlets hidden behind furniture or in hard-to-reach areas of your home. It's just over half an inch thick and charges devices super fast thanks to its USB-C port that supports Power Delivery. Though it's normally priced up to $45 at Amazon, right now you can pick one up on sale for just $25.99. That's the lowest we've ever seen it reach.
This high-speed USB-C wall charger can power up a 12-inch MacBook from 0% to 100% in just two hours. It doesn't come with a USB-C cable, so you'll want to make sure you have one handy when it arrives. However, Anker does include an 18-month warranty in case you experience any issues with its use. To keep it compact, Anker equipped this charger with a foldable plug and designed it to be 35% smaller than the comparable, yet much more expensive 30W Apple MacBook charger.
Be an expert in 5 minutes
