Anker's 3-in-1 charging cable is a must-buy at $11 no matter what phone you're rocking
You are now subscribed
Your newsletter sign-up was successful
We all need to power up a bunch of different devices these days, and the charging connector isn't always the same. Rather than rifling through a mess of cables to find the right one, pick up Anker's PowerLine II 3-in-1 cable in white for just $11.24 when you checkout using coupon code ANKER8436. It normally sells for around $15, and today's cost comes within half a dollar of the best price we've ever seen for it. Note that shipping is free on orders of $25 or more, but you can also use Amazon Prime or sign up for a free 30-day trial to avoid shipping fees. With three different connectors, it's capable of charging the gear you reach for most often.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The cable itself is three feet long. It has a micro-USB connector built into the end of the cable, and then there are attachments to convert that to a USB-C connector or a Lightning connector based on your needs. These additional converters are connected to the end of the cable so you won't lose them, and they click on to the micro-USB end with ease. Unlike some of the competing options out there, this Lightning cable is MFi-certified, which means Apple has approved it for charging your iPhone, iPad, or even iPod touch. I actually personally own and use this cable on a daily basis, and I love being able to switch from charging my iPhone to my micro-USB headphones in a matter of seconds. It's more convenient than any other cable I've ever owned.
Anker is so confident in the quality of this cable that it offers a lifetime hassle-free warranty, so if you ever experience an issue with it, the company will replace it without a worry. It has great reviews and really is the one cable that every smartphone owner needs. Pair your new cable with a discounted power bank to power up nearly any device on-the-go.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
