Plug in or charge on the go with the discounted Anker PowerCore Fusion
The Anker PowerCore Fusion 10000 2-in-1 wall and portable charger is down to only $29.99 at B&H. Considering it has retail price of $100, this is a huge saving. While we have seen some price drops on the smaller 5000mAh version, this larger option offers twice the internal battery capacity for not much more in terms of price and is also USB-C enabled for your newer devices. This B&H deal is part of its one-day DealZone promotion so is set to expire at the end of the day.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
It's called the Fusion because it serves two functions. It has a built-in 10000mAh battery, which you can use when you're not near a power outlet. But if you do have access to an outlet, you can just plug it in and charge your devices that way, recharging the device's battery as well. There's one USB-A port as well as a USB-C port so you can power up two device at once, and the plug folds up for a compact form factor while travelling.
It's worth noting that while this model has a larger capacity internal battery, it has a max charging output of 15W. There is a USB-C-enabled 5000mAh version that is exclusive to Apple stores that supports up to 30W with Power Delivery which may be more suitable for powering up your larger devices.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
