Anker's new portable power strip just reached its best price yet
The Anker Portable Power Strip has been selling for $24 since it was released back in July, but today you can drop the price to $20.39 with code ANKER192. That's the best price we've seen yet for this well-rated product. Shipping is free with Amazon Prime or on orders of $25 or more.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This power strip is equipped with two AC outlets and two PowerIQ USB ports. That means you can use it to charge four devices at once. The strip has a super compact design with a slim plug so you can place it in areas where bulky power strips wouldn't fit. The cable measures five feet long, so it might be the perfect solution to those pesky outlets behind your couch. It's also portable, making it perfect for travel. There are plenty of built-in safety features to protect your gear and your home, and your purchase also includes an 18-month worry-free warranty.
For more ways to educate your home, check out these discounted smart plugs.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
