Anker's Nebula Prizm home projector dropped to a new low price of $65
If you're someone who's dreamt of owning a projector but haven't picked one up due to the cost, you should look into Anker's Nebula Prizm 2500 Lux LED home projector. It normally sells right around $100 these days, but thanks to a current price drop and an on-page coupon you can clip to save $20, you can turn your dreams into reality for just $64.99 today. That's lower than it's ever reached before.
This is a fantastic budget option if you're looking for a good projector without a triple-digit price tag. You'll just need to clip the on-page coupon at Amazon to score this low price.
$64.99 $98.88 $34 Off
The Prizm can project a 800 x 480 resolution picture up to 90 inches (although 65 is the ideal max). It's bright with 100 ANSI lumens of light and has an up to 40-degree keystone correction. This device would be a great way to set up a small home theater in your bedroom or a kid's playroom. The darker you can make the room, the better it will look.
Get content on the big screen easily with multiple inputs including HDMI, USB, phone mirroring, and more. It has a 30,000 hour LED lifespan along with an optimized battery management system and a cooling fan for both reliability and longevity. Should anything go awry, your purchase includes a one-year warranty.
If you're on the hunt for an upgraded projector, the Anker Nebula Prizm II is available for $229.99. There are a few differences between it and the aforementioned model, mainly better brightness and resolution with the Prizm II compared to the original Prizm.
Be an expert in 5 minutes
