Here's how to save $130 on Anker's Nebula Capsule II portable projector
Amazon usually sells the Anker Nebula Capsule II Smart Portable Projector for $580, but by clipping the coupon on its product page and then entering code CAPS2AUG during checkout, you can nab it for only $449.99. This is a recently released product that just came out in March, and we haven't seen many price drops for it.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This gadget may be palm-sized, but it doesn't skimp on features. It creates a 720p 200 ANSI image up to 100 inches in size, and the built-in speakers have premium sound that'll immerse you in your content. It runs Android TV 9.0, so you can easily use over 3,000 apps, such as Hulu and YouTube, to stream your favorite media. The battery lasts for up to 3 hours and charges quickly, too. Setup is simple and focusing is seamless, taking only a second in most instances. Note that the projector works best in low-light environments.
For extra stability, you might want to pick up a tripod for your new portable pal. Keep it safe during transport with a carrying case.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
