Stock up on Anker's discounted car accessories, including chargers, dash cams, pressure washers, and more
Over at Amazon today you can save on a range of Anker accessories for your car with up to 37% off their usual prices there. There are some essential items in here to keep in your car or garage, and today's prices make them must-buys.
The one-day sale features a bunch of essential purchases for your car with prices discounted by up to 37% until the day is out.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
First up is the Anker Roav SmartCharge F2 car charger and Bluetooth FM transmitter. If you want an easy way to get your phone's audio onto your old car stereo, this is it. Plus, its 2 USB ports keep you powered up on the go. It usually sells for $27 but is down to a new record low price of $16.74 for today. If you just want a charger, the vent-mounted Anker PowerWave fast wireless charger is great if you want to charge up your Qi-enabled phone while using navigation or taking hands-free calls. It's 35% off at $30 right now.
The safety conscious will want to take a look at the Anker Roav DashCam C1. Today it is just $54.39 — almost $20 off its usual price. The C1 has shock detection and records 30fps 1080p HD footage with night vision to give you an accurate picture of any events at any time of day. The package comes fully-equipped with the camera, a 2-port car charger, and USB cable, though you'll probably want to pick up a 32GB microSD card as well so you're ready to go.
The Anker Roav Jump Starter Pro is also discounted in the sale, down to $71.99. We've seen infrequent coupons for this item taking it down to around $80, but this is the first time we've seen it drop this low. It combines an emergency jump starter with an emergency battery charger. If your car dies on you, you won't have to worry about being stranded in the middle of nowhere and you can get up to 15 jump starts from a single charge of this device. It has a built-in high-intensity LED lamp plus two USB ports for charging your mobile devices in a pinch with the 8000mAh battery.
If you like to keep your car looking clean, the Anker Roav HydroClean Electric Pressure Washer is for you at $112.49. It usually sells for $160 and rarely drops below $130, making now a great time to pick one up. It has an 1800W motor that provides 2100 psi of pressure for a deep, thorough clean. Its 35-foot long cable and 26-foot long hose make it easy to clean all around your vehicle or get your entire patio or driveway looking like new again.
There are a bunch more items in the sale, so be sure to check it out in full and get your orders in before the day ends and prices rise.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
