Grab Anker's LC30 pocket-sized Cree LED flashlight for $5 off
The Anker Bolder LC30 pocket-sized Cree LED flashlight is down to $8.49 with code ANKERLC30 on Amazon. That's almost $5 off its regular price and the lowest ever discount on this flashlight. Considering the inexpensive starting price, $5 off ain't bad at all.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This is a powerful, compact, tactical flashlight based on Anker's series that includes versions like the larger LC40 flashlight, which we have featured before. The flashlight has a scalloped bezel, straight body, and anti-slip design that fits in your hand or pocket. It's a great little light, whether you slip it into a drawer or keep it in your pocket while you're camping. The Cree LED uses a highly efficient design so it has a 50,000 hour lifespan and regular high brightness. The light uses three AAA batteries, so you'll want to add a few to your order.
