Power up your phone wirelessly with $4 off Anker's 10W charging pad
The Anker 10W Qi-certified wireless charging pad is down to $9.99 on Amazon thanks to the $4 off on-page coupon you can clip. The charging pad normally sells for $14 and has never dropped lower than $13 directly. It has been selling for $14 since February.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This pad does not come with a wall adapter, and you'll want one with Quick Charge 3.0 if you plan to use that tech, so grab that additional accessory to ensure you're getting the fastest charge.
The pad provides 10W high-speed charging for Samsung Galaxy and similar phones, and it provides a 5W charge for any iPhone with wireless charging. The LED indicators lets you know the charging status of the device, including whether or not the phone's case is too think or there's something else between the phone and the charger. Luckily, the pad works with most cases up to 5mm thick. Any metal or cards in the back of the phone will prevent charging. It comes with an 18-month warranty.
